"Service Required" indicator on dash board
1 Attachment(s)
I just got a "Service Required" warning on the dash board console.
It is a 2007 XLS with Navi. Please refer to the picture. Anybody experienced this before? What is this? releated to TPMS sensors? Thanks! |
The owner manual is a good starting point.
I would say you need a new battery in your remote key. |
1 Attachment(s)
Originally Posted by Claude_A
(Post 287950)
I would say you need a new battery in your remote key. You're right that it is about the remote key. However, it does not seem to be the battery. I did get the "Key Low Battery" error messages several times in the past and fixed the problem by simply replacing the battery. The "Service Required" error messages are sporadic. I'll do a battery change if this does not go away tomorrow. Thanks! |
GPSeek, if you're in GTA I can read what exactly wrong is with your immo ECU.
Originally Posted by Vadimus
(Post 287958)
I googled GTA and found out it is Toronto area. That is 500 miles from tristate area. I was quite close to Toronto this summer, driving to Niagara Falls, ON with my 07 Outlander. Thank you again fort your kindness. |
Originally Posted by GPSeek
(Post 287964)
Thanks, Vadimus.
I googled GTA and found out it is Toronto area. That is 500 miles from tristate area. I was quite close to Toronto this summer, driving to Niagara Falls, ON with my 07 Outlander. Thank you again fort your kindness. If you update your profile with your location there may be other local members who can help you. |
you can go to an auto parts store and rent/borrow an OBDII/CAN reader to get the code. once we have that, we can start digging into what is happening.
An update
Here is an update to this error message.
Now I think this error message is really a warning for the real battery, the lead battery under the hood! I come into this conclusion because I also ran into startup issues last week and finally had to replace the lead battery on Sunday night to get the car started. I see no more such error messages for the last 2 days. The battery that came with the car lasted for 5.5 years and 92K miles. How long did your OEM batter last? |
I replaced mine this summer. a bit over a year ago I opened the old battery up and noticed the acid level was low in several cells.
(Post 288305)
| All times are GMT -5. The time now is 11:54 PM. |
