side moldings for 2010 outlander?
i am looking for body side moldings for my 2010 outlander.
the color is diamond white. is there anybody ever installed that? pls give my any suggestions. thanks in advance :) |
1 Attachment(s)
www.sportwing.com has some but they don't show them on their web site. Search ebay for "sportwing outlander" and you should find the info. I installed them on my Diamond White outtie, perfect match and fit.
https://mitsubishiforum.com/forum/at...1&d=1303596565 |
thank you so much
Biscuit,
thanks a lot, so the paint code of Diamond White Pearl Tricoat is W13, right? I will go ahead to order a set. thanks again:D
Originally Posted by biscuit
(Post 271977)
It's been a few years so I can't remember what I ordered. The link on the ebay listing says CMW10013 for Diamond White Pearl. I'd recommend giving them the make/model/year/color in addition to the code. I mounted mine lower than their instructions showed. Just above the body line, see the photo.
thanks a lot
i find there are two paint code for diamond white, CMW10013 and W13..... http://www.automotivetouchup.com/cho...odel=Outlander
(Post 272022)
(Post 272022)
So far, knock on wood, I haven't got any door dings. I measured it against our Accord and it's the right height to protect from sedans. You can mount it higher for protection against SUVs, but then you might get dinged by sedans. I went for the lower position because I think it looks better.
(Post 272132)
you are right, also sedans are more often to see than suvs... thanks |
biscuit,
did you cut off little bit to make the side molding shorter for rear doors? because you installed the molding lower than the instruction? thanks |
5 Attachment(s)
Nope, didn't have to cut anything. Here are some more pics for reference. I laid down a strip of red vinyl tape as a guide to help get the position exactly where I wanted it.
