Steering 09 outlander ( out of whack )
Old Dec 7, 2010 | 08:19 AM
rmiranda's Avatar
Originally Posted by Ricbec
and this one is even a bit later.....
this isnt your first front wheel drive car by any chance is it?
Not at all, I've had quite a few in the past.
I took it out for a drive on the weekend and tried to find some pretty straight street with out any snow on it. At times it's super straight. However at times I get a pull to the left and to the right. No ruts on the street.
The only reason why this sucks is I do quite a bit of highway driving. I find that I have to consistent hold the wheel down on either side while driving on the highway ( I know this sounds odd ). Just imagine holding your while 1 / 2 degrees off for two hours while on the highway.
Roger
Old Dec 7, 2010 | 10:26 PM
bleacherbum's Avatar
Is it possible that it is pulling to the "low" side of the road ? Or could wind be a factor? I have noticed that my 07 seems to be a bit over-sensitive to these conditions.
Old Dec 22, 2010 | 11:03 PM
ivanz's Avatar
I don't actually see a problem from your description unless it always goes in one direction when you let go of the steering wheel. I have a sports sedan which does this 10x more than the Outlander...you literally have to always have a firm grip on the wheel so that it doesn't run away from you depending on the road surface. It is totally normal, and you get used to it.
If you want it to stay straight, you basically need a car that has less precise/numb steering wheel. Shouldn't have bought an Outlander but something with a ridiculously strong power steering motor.
wired4sounds
Sep 12, 2021 02:53 AM
Ozzyuk
Sep 2, 2018 02:17 PM
BrianB
May 15, 2012 04:21 PM
adam3250
Nov 4, 2010 07:14 PM
chenarm
Sep 25, 2009 08:59 AM
