Sti wheels for 2011 outlander
Old 08-19-2011, 10:08 PM
etp's Avatar
etp
etp is offline
Default Sti wheels for 2011 outlander
I just picked up a 2011 Outlander ES today, I had a 2006 Sti and I still have my work emotion cr kai 17 x 8 47 offset, 5 x 114.3. Does anyone know if these will fit on the Outlander. Also, I was thinking of putting on 245/55/17 tires on them.
Old 08-20-2011, 07:27 AM
Claude_A's Avatar
Stock wheels for the Outlander
Bolt pattern (PCD) is 114.3,
Center bore is 67.1 mm,
The offset is 38.
For the 18", the rim width is 7"
For the tire size go there and play Tire size calculator
Rolling diameter wise they are a perfect match.
If the center bore is OK they should fit
Old 08-20-2011, 09:23 AM
kalayaan's Avatar
your sti wheels might just sit 9mm farther in because of the difference in offset.
make sure you have enough clearance between the tires and strut.
Old 08-20-2011, 04:05 PM
atx25rs's Avatar
I think, i had read that the center bore is slightly off, but should physically fit. i also came over from a suby, but i never had an sti. all my wheels were 5x100. let me know if they fit, nasioc always has deals on the bbs wheels.
Old 08-20-2011, 08:51 PM
etp's Avatar
etp
etp is offline
Talked to a couple of tire shops and they said it should fit but I'll need new hub rings. I'm going to do a test fit hopefully this week and let you know.
Old 08-21-2011, 03:58 PM
MITZA's Avatar
Deff like to see a pics when they are on.
Old 08-25-2011, 11:08 PM
QwikEVO's Avatar
mitsu hubs are too big for subaru wheels.
Old 08-26-2011, 08:39 PM
etp's Avatar
etp
etp is offline
Put them on today, they fit no problem just needed new rings. However, it was hard to find 245/55/17 tires so ended up getting 225/60/17 yokohama trz's. I'll post pics soon.
Old 08-28-2011, 03:21 PM
MITZA's Avatar
Cool I still wanna see the pics.
Old 08-29-2011, 06:02 PM
etp's Avatar
etp
etp is offline
Previous
current
Quick Reply: Sti wheels for 2011 outlander
