test fit led strip as drl
didn't like the dealers answer of leaving lights in 'auto' to have "drls" so picked up a waterproof strip of side emitting ones from superbrightleds, its a meter long and i'll cut it into half (almost, the dividers dont split it evenly so lose like a 3 inch segment in middle with 4 leds to get two strips out of it)
ordered them in 'natural white' because can't stand the yellowness of warm white, and was worried the cool white might be too blue, plus the natural according to specs put out the most light of all of them
the pics aren't quite right, they don't look that warm in reality, its a cleaner white in person than what it looks like
I'm not quite sure how the full size Outlander headlights would work with this, but one of the guys on a different Mitsubishi forum I'm on figured out a really great way to use LED's on his Outlander Sport:
Project Blackout - Page 4 - evolutionm.net
Basically you'd use "side-firing" LED strips instead of the front firing ones that you have currently, and it reflects throughout the headlamp really, really well.
thats interesting what he did, i'll have to go back out and see how the crystals on the wifes outtie are because i dont think its quite the same and couldn't get that effect with hers
just cut the strips and siliconed the end caps on waiting for those to set
4300K is pretty "natural" white. 5000K is technically "cool" white, but for some reason most LED suppliers tend to use closer to 6000K for "cool" white, which is a blueish-white like you have there, Vadimus.
Do you recall where you got them from?
4300 is standard for incandescent lighting (which is a dingy yellow) standard noon time overhead high overcast light is technically around 5600k (natural white) and 6000 is closer to the bluish of arc type lighting (many early hids, strobes, etc)
i can't stand warm lighting, every 'regular' bulb in my house is a daylight cfl, much prefer that to standard cfls or incandescent bulbs
Like you, I prefer 5000K-5600K for most of my lighting.
Also, bear in mind if ordering HID's or other headlamp bulbs, 4300K has greater usable light output than the higher Kelvin values.
most helpful post ever...
well then, good thing it's my wife's car and not yours
that's also not the finished product just getting a rough idea of how it worked /looked, it'll be two smaller strips one over each headlight
