Tint Window films scratched
Has anyone tinted the front driver-side and passenger-side window then late find out the tint film scratched by the window insert? this is for 2007 outlander XLS. Is there a re-call or technical info related to the side window insert? Please HELP ... Thanks in advanced
I have the same problem. It's thin lines on the driver side window. Probably issues with the window insert being too tight and it's scratching the tint film. I'm not going to redo it.. the problem will reoccur again, unless the tint shop figures a way to fix it.
Guys,
This is probably what u need: http://www.tintprotector.com/index.htm
It should have been installed on your vehicle when the tints were first done.
Check it out and good luck !!!
Russ
Russ
Guys,
This is probably what u need: http://www.tintprotector.com/mitsubishi/
Russ
Russ
