torque setting for an oil plug
Hi. I need the torque value for the oil drain plug in a 2007 mitsubishi outlander.
thanks!!! |
Hi,
This is from the service manual: Oil pump Oil spray jet bolt 25 N·m Oil pump sprocket bolt 20 N·m → +90° Oil drain plug 30 N·m Oil sump bolts 15 N·m Baffle plate bolts 15 N·m Suction line bolts 15 N·m Chain tensioner with tensioning rail bolt 15 N·m Sealing flange bolt 15 N·m Oil filter bracket Bracket bolt 10 N·m Plug 25 N·m Sealing cap 25 N·m Oil pressure switch 22 N·m Oil supply line 22 N·m Connection 30 N·m |
thanks!!!! so that's 22 ft/lbs.
appreciate it!!! :-) |
Yup.
22 1/8 to be exact :D |
Originally Posted by silverflash
(Post 248019)
thanks!!! |
