Trailer Icon on 2007 xls
Hi: I noticed that there is an icon of a trailer on the dash that never lights up? I have the towing package and wonder if there is anything that I need to do because I tow a boat during the summer. Thanks
Do any of you have the OEM trailer plug? I have the OEM plug but have nothing to plug into it.
I noticed the icon I figured it came on when the trailer was plugged in.
My concern would be that you really shouldnt tow in auto, it would cause the tranny to shift in and out of 4,5,6 too often and cause it to heat up.
Especially if you dont have the 4wd model with the tranny cooler on it.
Someone in Europe mentionned that the parking assistant sensor (It's an option they can have) can detect that a trailer is attached (probably if you use the OEM wirring), and disables the sensors. I assume that might be what the light is for?!?
I've noticed it, and did check the manual for a tow mode..didn't see anything.
I thought of 3 theories:
It'sa global model, there could be some engine/transmission combo somewhere else
The cluster is used on a different vehicle that has this feature
Future proofing.
Future proofing.
millie
01-02-2006 05:08 PM
