-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Tweeter/bluetooth problem (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/tweeter-bluetooth-problem-48611/)
stanza75 Aug 2, 2015 12:38 AM
Got 2008 outlander. Both tweeter used to work fine when i connect my phone using bluetooth. Since last monday though,the driver side tweeter stopped working when i connect my phone using bluetooth. The passenger side tweeter is working fine. Any suggestion will be appreciated.
Guyfromhe Aug 2, 2015 09:57 AM
Is it only your phone + bluetooth or is it the radio too?
If it's everything it's probably either a bad wire/connection or a bad speaker.
stanza75 Aug 4, 2015 12:24 AM
My car is at the Mitsu dealer for couple days. Once i get it back im going double check to find out if the tweeter problem happens with radio too
stanza75 Aug 5, 2015 11:43 PM
I just checked the tweeter and found out that its only stop working when i connect my phone using bluetooth. The radio side, both tweeter works fine. Going try use another phone just to make sure if its a phone problem
