Weird problem need help
Got into my outlander today and the driver side interior dome light didnt turn on'
All other interior lights turned on so its not the fuse. I have tried replacing the bulb but it still doesnt turn on! Whats going on? does the driver side dome light have a separate fuse? Can anyone help? thanks in advance |
My passenger side did that a few days ago.
I just rotated the bulb in the socket a bit to scrape any oxidization off the contacts and it lit right up again. The bulb and the fuse were fine. Maybe try this?
Originally Posted by ajoesmith
(Post 278120)
(Post 278120)
All other interior lights turned on so its not the fuse. I have tried replacing the bulb but it still doesnt turn on! |
Originally Posted by tcp
(Post 278124)
Im stuck. |
Have you checked for voltage at the bulb socket?
Probably the door switch. I have never examined the switches as never had one fail, but probably worth opening it and connecting the wires to see if this turns the light on. Or just check the voltage at the switch.
Originally Posted by benshepherd
(Post 278136)
Just open the door and look on the body of the car (not the door) adjacent to the big metal bracket that the door engages with to hold the door closed (sorry, that is a poor description, I dont know the names of those parts!). The switch is contained in a rubber housing that protrudes out and the door presses on it when the door is closed. Pressing and releasing that switch with your finger will turn the light on and off.
If you cant find it let me know and I will email you a picture. Ben |
found the problem, this switch in the dome light http://www.miyama.co.jp/pdf/MS-010.pdf
does anyone know where to get a new one? |
maybe
check out the datasheet of this:
Digi-Key - CW171-ND (Manufacturer - GC-536BQ-0400) otherwise, maybe one of these (i can't read the dimensions of the picture you posted): Digi-Key - CW170-ND (Manufacturer - GC-536B-0108) Digi-Key - CW167-ND (Manufacturer - GC-536-0002) Digi-Key - CW169-ND (Manufacturer - GC-536-0203) Digi-Key - CW168-ND (Manufacturer - GC-536-0102) Digi-Key - 527PB-ND (Manufacturer - 40-4169-00) |
| All times are GMT -5. The time now is 09:11 AM. |
