What other vehicles have compatible wheels?
Old May 13, 2013 | 05:17 PM
longboq's Avatar
Default What other vehicles have compatible wheels?
I find all kinds of good wheel and tire deals on CL. Is there any known vehicles out there that have wheels/tires that are a perfect fit for Outlanders?
Old May 14, 2013 | 04:11 AM
Burtonrider10022's Avatar
You need to start by posting your exact vehicle specs, and saying where you're located (but by mentioning CL I'm going to assume you're here in the US). You can add your location to you Profile in the "User CP"
Here is the info I used when shopping for my own rims for my snow tires for my 2011 Outlander Sport:
I snagged some 16" rims off of a Hyundai Sonata for $80 picked up. They're flawless!
I got them for some snow tires and it seemed to me that all years of Outlanders for the most part had the exact same rim specs. Double check everything, but it should be any rim with: 5x114.3 lug, 46mm offset, 67.1mm Hub Bore. The 16's were 16x6.5 and the 18's were 18x7.
Tires for the 16's were 215/70R16 or 225/60R16 I believe. I know when I used a "diameter calculator" the closest match to my Outlander Sports' 18's was the 215/70R16 size.
This site will show you every other vehicle with those rim specs: Wheel Bolt Pattern Cross Reference Database and Conversion Guide: 5 X 114.3
If you do, in fact, have the 5x114.3 pattern I listed above, then congratulations, because thosse are the most common rim specs in America.
Old May 14, 2013 | 10:11 AM
longboq's Avatar
Thanks thats exactly the type info I am looking for. FYI Its a 2009 Outlander. USA
Old May 14, 2013 | 04:06 PM
JRK5892's Avatar
the stock wheels are 18' 5x114.5 with a 38 offset... so this means that Hyndi senotta, charger, eclipse, few VW's fit... i have been ebay/craigslist stalking for months for a set of nice 18-19 bbs wheels for powder coating
Old May 14, 2013 | 05:11 PM
longboq's Avatar
Are you sure about the 38 offset? Burtonrider10022 said its 46 offset.
Old May 15, 2013 | 01:05 AM
I have an Outlander Sport SE 4WD w/ OEM 18" rims, it could be slightly different than a full size Outlander's rims.
I am positive about the Sport model being 46mm
Mitsubishi Motors Newsroom
I checked several years of the Outlanders from 2009 to current and they don't list the rim specifics. Mitsubishi Motors Newsroom
Old May 15, 2013 | 09:07 AM
JRK5892's Avatar
Yep the sport is a 46mm off set and the full size outlander is a 38
Old May 16, 2013 | 01:32 PM
ckmecha's Avatar
For reference I have these on my GT:
Sparco Assetto Gara Black Painted
18" with a 45mm offset. There are no interference problems at all. There are cheaper solutions though.
Like Burtonrider said, make sure you do the math on the OD of the tire so you dont have to reprogram your speedometer.
Old May 17, 2013 | 04:38 PM
kizzdog's Avatar
i put some 18" 235 55 bought of ebay brand new tyres cost me $900aus fit perfectly offset was 45 mm i think cant remember great buy grip is 100x better and looks awsomeWhat other vehicles have compatible wheels?-imag0154.jpg
emery65038
Oct 18, 2011 11:01 PM
weaponr_ray
Nov 20, 2006 07:41 PM
shiny
Jun 29, 2006 11:40 PM
lyn
May 22, 2006 09:03 PM
