Wheel Hub Bore Size
Does anyone know the wheel hub bore size on 2008 Outlander XLS?
Anyone?
youve got one. Go and measure.
On stock 18" wheels for the Outlander
the bolt pattern (PCD) is 114.3mm, the centre bore is 67.1mm, the rim width is 7" (JJ or J ) and the offset is 38mm. By the way, it's in the manual at the end, in the spec section. |
