Wheel locks for steel rims for outlander
Hey all,
Any idea where or if you can get wheel locks for steel winter rims for the Outlander? I have the wheel locks for the alloy rims, but I have picked up tapered lug nuts for the winter rims and doubt I can use the same locks. Has anyone picked some up? I live in Canada - so far Napa, CT, do not have them. Thanks! |
I used the same ones that came stock with my Outlander.
Try Kal-Tire yet? |
your OEM nuts and locks are the same ones that you can use.
they are also tapered. |
Been using the same OEM one from my alloys for 3 years on my winter steel wheels no problem as it's tapered !
Hey,
So I am assuming the OEM nuts and locks are the same for the LS and it is for the XLS? I remember a few people saying that I should get different lug nuts for winter rims since the taper was too small on the OEM nuts. That is why I didn't think that the OEM locks would work either. So, using new acorn lug nuts (more tapered) and OEM locks will be fine then? Thanks! |
Yep should be fine
