Winter tire question
Hey all,
Pretty stupid question, but since the winter tires and rims I use have different lug nuts, do you still torque them at ~80 ft lbs as you would the regular rims with the original lug nuts? Thanks |
good question actually....
I think tourque is based on whell weight and requirements. So it would be according to the winter rim specs i would think...not positive...good question. |
Originally Posted by ryandlor
(Post 288582)
I think tourque is based on whell weight and requirements. So it would be according to the winter rim specs i would think...not positive...good question. The guys at the tire shop said that torquing the steel winter rims to the same as the alloy ones for the rest of the year will be fine, even though they are a different type of lugnut and obviously on steel rims, not alloys.... So I put them at 80 ft lbs..just like I do for the alloys. However, I did notice one of my winters is 2-3/32 lower than the other 3 tires!!! They suggested putting that on the rear and not using the 4wd very often...Bloody hell. He said that if left in 4wd it would wear out the differential. ugh |
Look in your manual and see what it says about tire circumfrence. There is a paragraph on it but I forget what the spec is.
Originally Posted by milliesdad
(Post 288617)
Measuring it it seemed about 1/3 of an inch difference in CIRCUMFERENCE. I know Subaru states it cant be more than 1/4" for their AWD system..but mitsu doesn't state any specs... I called a few dealers and they said it would be fine, but I am not really sure what they are basing that on since no one could point me in the direction of any written figures.... Thoughts? |
