Just signed up to the forum. Many thanks for the uploads of the repair manuals people!
I wish someone had the 2021 Outlander Sport service manual. It's nowhere to be found online.
Can someone please renew the access or the links?
Unfortunately they are no longer active... |
Originally Posted by Aditi
(Post 338595)
Unfortunately they are no longer active... Back to Honda/Toyota for me. |
Yesterday I found this URL with 2017 Workshop Manual in English (this includes 4N14 Diesel Engine). I'd say that I only found 4N14 in two Manuals: 2013 and 2017, not between.
So I'm sharing it. Note: I do not know the source. So use at own risk (or in a Virtual Machine) since I think it needs admin rights. Also, for each image shown in the manual (that has low resolution) I think there is also a PDF with the same name that can be zoomed in without losing quality, these files can be found in the installation folder. EDIT: it seems the 2017 it installs and execute just fine in Windows 11 without having to do what I mentioned above. I installed first "D:\Mitsubishi ISO\Mitsubishi ISO\17OUTLANDERGF\TOOL\VISTAMSV\InstallMSV.exe" then I opened "SMVCD_KICK.exe" pressed the install option, had to do one restart, then opened again "SMVCD_KICK.exe" pressed install button again, this time started installing things, then I just open the SMV with "Service manual viewer system" desktop shortcut. Since this requires admin rights and the publisher is "Unknown", I did this inside a VMWare just in case. Anyway, this looks like the same manual here: http://mmc-manuals.ru/manuals/outlan...7/index_M1.htm so downloading it is even more optional. Irrelevant fact: My Outlander is a 3rd generation 2.2 DID "first facelift" 2014/2015 and looks similar to the one in 2013 manual, but 2013 manual mentions less than 7 liters of Oil engine, and the 2017 manual oil capacity seems similar to mine. So just in case I check both of them). |
Originally Posted by amenotef
(Post 340478)
So I'm sharing it. Note: I do not know the source. So use at own risk (or in a Virtual Machine) since I think it needs admin rights. To use this in Windows 11 (since I think it is for Windows Vista), you can launch the app from the downloaded zip, then install it, then you go to C:\MITSUBISHI\MUTSW\MUT3\MENU\SCRIPT --> open Command Prompt as Admin in this path --> run start.js --> And the manual should open. Also, for each image shown in the manual (that has low resolution) I think there is also a PDF with the same name that can be zoomed in without losing quality, these files can be found in the installation folder. Anyway, this looks like the same manual here: [W/M]OUTLANDER (GF#) so downloading it is even more optional. Irrelevant fact: My Outlander is a 3rd generation 2.2 DID "first facelift" 2014/2015 and looks similar to the one in 2013 manual, but 2013 manual mentions less than 7 liters of Oil engine, and the 2017 manual oil capacity seems similar to mine. So just in case I check both of them). |
Originally Posted by whippersnapper
(Post 340480)
Thanks. For those that aren't tech savvy, if it needs admin rights, it's obviously a bad sign, especially for a PDF. Definitely use it in a sandboxed/offline environment if possible.
| All times are GMT -5. The time now is 06:34 AM. |
