ZH Intsrument Cluster into a ZG
Hi Guys
I know this has been done before by a member on here - im looking for a bit of specific info
Instrument Clusters- where do they get thier info from
Im looking at changing my instrument cluster from my V6 outlander - I have the opportunity to get a ZH cluster from a wreck - but is only a 2.4l Auto vehicle
Will this be a problem? - or does the cluster get all its info from the car itself?
my concern is will the instrument cluster still show the full 6 gears that the V6 has - as well as any other info specific to the V6
Hi Guys
And no, cluster has no engine- or transmission-depending abilities.
You also need to set the odometer reading, as it is stored in the cluster.
Make sure you get the right cluster for your region, as there are minor differences (i.e rear fog light LED missing on North American version).
hi all
well i have my instrument cluster, this one could be up for some modding as i prefer the appearance of the speedo and tacho dial background over the background of the ZH model....will post up some pics if i am able to do what i want
the main question though is.....how to dismantle the dashboard!, i cant find any info on the net on how it comes apart, and i do not want to just start yanking on things to figure it out, so any advice would be great thanks
It is pretty straighforward.
Pull left - oh no those Aussies - right went, unscrew top cover with "goggles" (lift it up, it will unfasten), 4 more screws and cluster is out.
Once you remove it carefully unlock all latches.
That' it.
That' it.
engjye
09-06-2004 05:41 AM
