-   Mitsubishi Raider (https://mitsubishiforum.com/forum/mitsubishi-raider-61/)
-   -   Raider 07 Headlight bulb replacement (https://mitsubishiforum.com/forum/mitsubishi-raider-61/raider-07-headlight-bulb-replacement-37971/)
Rodz924 Dec 24, 2010 10:32 AM
For DIYers
There is no way to swap this bulb out without pulling out the headlight housing. there is no easy way to access the back side... to swap out the Hi/Low beam bulb, there are three bolts to remove on the headlight housing.Two to the inside and one bottom outside. You may have to lower the bumper to get at the bolt on the bottom outside or use a very long drive to reach in above the bumper. the top outside of the housing has a snap in post that can be pried after the first three bolts are removed. It takes a H13 2008 Bulb. Turn fixture 90 degress to remove/replace. Probably should disconnect ground wire off battery prior to start just to be safe. A pair of bulbs can cost you 20 to 40 dollars depending on brand/style. Good luck.
jacobt1978 Mar 6, 2016 03:23 AM
Use extreme caution when removing the assembly. I broke 3 fasteners trying to remove the assembly. And the two plastic rivets have to be replaced because mine would not unscrew I had to use a rivet puller to pry them out and the tip expanded like a drywall anchor.
