camshaft position sensor
Hello i need to know the location of the camshaft position sensor location on a 2000 mitsubishi eclipse gt 3.0
https://www.rockauto.com/en/catalog/...on+sensor,7192
SOURCE: crankshaft position sensor location Hello. One way to check if it is working is when you try to start the car does the needle move on you tac? If not then your crank sensor is more then likely the problem. It is located on the backside of the engine under the intake manifold. It is in about the center of the block. There will be a 10mm bolt holding the sensor in. If you decide to change it yourself (not to terrible of a job) unplug the sensor, remove the bolt and spin it back and forth slightly while pulling it out. It may be a little hard and you might have to work at it for a little bit (not a lot of room) but it will come. When it's out the sensor will be shaped kind of like an L. I have changed a few of these over time and they can be a little stoburn. To install just reverse the process. |
