Crankshaft Sensor 2002 Mitsubishi Lancer
Hi all,
I am replacing my Crankshaft Sensor, While removing the lower belt cover. I found a bold behind the Crank Pulley Which I cant get to unless I remove the Pulley. Does any one knows if I removed the Crankshaft Pulley will effect the Timing belt? Because The Belt was changed 4 month ago. So all is good in this part and don't want to mess with the timing belt. So please I need to know if the Crankshaft Pulley will effect my timing belt or not? Thanks and regards. |
| All times are GMT -5. The time now is 07:44 AM. |
