Montero '96 3.0 LS Electrical Problem
Hello,
I've been having a problem with negative wire on the battery burnt and been advised to check on the ground wire. can somebody point out where the ground wire is located especially the one runs from the starter?
I am assuming if I have to replace is fairly easy process. Thank you in advance.
