Wet patch in my rear passenger footwell
Hello all
I've recently noticed a wet patch on the floor in the rear passenger footwell. Has anyone else had experience with this problem and how did you solve it |
Sorry forgot to mention it's a 2010 Mitsubishi ASX
Front passenger footwell is usually a clogged air conditioning drain. Rear is usually a clogged or loose sunroof / window drain. With sunroof open, look to the rear under the roof. Drains exist on both sides. You can easily test with a bottle of water, looking under the car for where it comes out. Trunk area water is usually a tail light assembly not sealed to the body. Check door/hatch/trunk seals are seated properly. Check door drains are not clogged.
Originally Posted by Jonstafford
(Post 326325)
Hello all
