1992 Eclipse Turbo????
Hey every1.
I have a 1992 Eclipse 16valve DOHC non-turbo automatic with overdrive.
The thing is I wanted to know if you could put a turbo into an automatic, and if you can what all needs done to do so. Please get back to me ASAP.
Thanks,
Jesse
Thanks,
Jesse
RE: 1992 Eclipse Turbo????
yes you can, but at the MINIMUM you need to get...
gst ecu
gst injectors
gst fuel fuel pump
manifold
turbo
down pipe
charge pipes
bov
smic
plugs
wires
your better off buying a gst/gsx with a blown motor and switching everything except for the block and the drive train.
gst ecu
gst injectors
gst fuel fuel pump
manifold
turbo
down pipe
charge pipes
bov
smic
plugs
wires
