4G63 Non-Turbo to Turbo
Old 11-18-2006 | 06:26 AM
GermanEclipse's Avatar
Default 4G63 Non-Turbo to Turbo
hi.
I have a 95 Eclipse Non-Turbo. its the 4g63 Engine.
Can i build it up to a turbo engine with parts of the 4g63 Turbo like crankshaft, pistons and Rods?
It have not enough Horsepower.
yes, i come from germany[8D]
Old 11-18-2006 | 07:22 AM
silvercoupe97's Avatar
Default RE: 4G63 Non-Turbo to Turbo
Hi GermanEclipse.
I would like to ask if you are sure that your 95 Eclipse is a N/T 4g63. The reason I ask is because Mitsubishi made the N/T 2Gs with a Chrysler 420a motor. The 1G Eclipse utilized the N/T 4g63 in 1.8L size, but not in the 2nd Gen.
If the motor is on the passenger's side (you guys have the driver seat on the left correct?) it's the 420a. I just want to be clear on the motor first.
Old 11-18-2006 | 10:45 AM
If he has a spyder he has a 4g64.
but 95 N\A is def not a 4G63
Old 11-18-2006 | 11:24 AM
its not a 420a.
Its realy a 4g63 Non-turbo 7bolt.
Its on the passenger's side. I have the driver on the right if you sitting inside.
I've ask at ebay. someone says that the parts fitting
Old 11-18-2006 | 11:29 AM
Old 11-18-2006 | 11:40 AM
link doesnt work
Old 11-18-2006 | 02:22 PM
Look at www.mobile.de
You search at a Mitsubishi Eclipse Baujahr von 1995
There are a lot of posts to this. You must look at the pics than you will see that it is def. a 4g63.
in the instructions of the car the engine is a 4g63
Old 11-18-2006 | 04:09 PM
Hallo. Willkommen zum Forum!!!
Ok i have to post here. Since im the only one that knows German i feel my input is needed.
There ARE 4G63 non turbo 2g Eclipses in Europe. They are called the GLsi or something like that. They DO exist.
It is easier to buy a turbo eclipse engine rather than rebuild the non turbo one. Because you need ECU, exhaust and all thost things. If you do buy a turbo eclipse engine it should drop in fine.
Try ebay!
Old 11-18-2006 | 10:37 PM
ORIGINAL: Sebba
Try ebay!
Thought maybe there might be
Old 11-19-2006 | 01:16 PM
ok.
you mean i can build it up tu a turbo with special parts for the 4g63 Turbo.
like je Pistons, eagle rods and camshaft...
and the ecu i can buy at ebay and programed it for the engine and Horsepower....
Quick Reply: 4G63 Non-Turbo to Turbo
