BOV return hose
BOV return hose
.........This is for a 2gen eclipse with a 1gen bolw-off valve.............
I have read that taking the BOV return hose off of the BOV would cause idle, and stalling problems. Is there any way around this, and does it happen with aftermarket setups??
RE: BOV return hose
It happens because of the stock Mass Air Sensor. Without recirc. that air the engine will run really rich because it thinks it has more air then it is actually getting. The only way to truely vent is with a standalone, or a translator. But i dont suggest going with atrans because ive heard they can be a nightmare to tune with. My suggestion is to just recirc.
RE: BOV return hose
i put a tube on it after i got my car, and it felt more smooth when idling in the heat of summer. but they do got a point in that it's bad for your car to vent it if you have stock boost. and with a 1g BOV it's not made to vent in the first place so i would advise not doing it. sebba is right, the air will be colder not by much with the stock intercooler but it will be colder than the air outside the car with driving, idling i think it will stay the same as the air outside.
