Greddy Emanage
I am going to get a turbo kit setup for my car and was going to buy the Greddy Emanage kit for the turbo. How exactly does that work? And How do i make it work for my car>?
RE: Greddy Emanage
E-Manage is for people pushing 500+hp.
Apexi SAFC II woul do fine. What it does is over rides the signal from the ECU that controls the a/f ratio and the SAFC or E-Manage what ever takes that signal and changes it. |
RE: Greddy Emanage
But isn't that the reason you take it to a performance shop to get it tuned?
RE: Greddy Emanage
Oops i just had this whole thing on why not to get the emanage thinking you were a 2g guy but i realized your a 3g car. Next time just specify the car because that will help alot more. Definetly go with the e-manage since the SAFC wil not work with the 3g. Oh and to tune with the emanage you use a laptop.
RE: Greddy Emanage
Oops. I asumed 2g as well.
RE: Greddy Emanage
No dont use an SAFC on a 3G the ECU is smart in those cars and it can override your correction with the SAFC. the Emanage is the only piggy back that works other than the ripp black box and grey box.
The emanage needs a laptop to be tuned |
RE: Greddy Emanage
Wow, see would I tune it to set a certain boost?
RE: Greddy Emanage
you dont tune that for the boost. that doesnt controll boost. You tune that to make sure the car is running a safe enough AFR and timing to handle the boost
RE: Greddy Emanage
But isnt' this just if you are running high amounts of boost?
