heat range on spark plug
1...2.....3????which is better.....and also could this be my slave cylinder....kinda of a humming and it stops once i press my clutch in......also a starting problem put new starter and still didnt start...then i took to the mechanic and he said it was a kill switch fropm my alarm and i would have to get a new alarm and is should start fine....but for now he rigged it so i could start it also bypassed the clutch...but still take 6 trys before it starts.?????could that be the prblem
RE: heat range on spark plug
A slave cylinder wont cause a no start, maybe a shifting concern but that abt it. Sounds like u have a wiring issue.
This website seriously has everything you need for a mitsubishi
