How to Install Greddy Turbo TImer? 2G
So i got a Greddy Turbo Timer and i need to know how to hook it up in a 2G eclipse. What do i hook up to the Red, green, blue, black, brown,grey, and purple wires? The turbo Timer is GTT2 92775. Thanks
RE: How to Install Greddy Turbo TImer? 2G
Do you know how to do it without a harness? thanks
well after about 2 minutes of searching i came up with these few links. First is the HKS TT install (basically the exact same thing)
http://ca.dsm.org/FAQ/2gtt-faq.html Then here is the actual manual for the Greddy TT http://www.greddy.com/img/PHP/products/pdf/685.pdf And finally i urge you to buy the harness for it. This willmake your life a hellovalot easier in the long run. You can get one here http://www.dsmparts.com/customer/pro...163&page=1 |
I had a carelectronics professional hook mine up..I have a GReddy turbo timer as well and he did a fantastic job doing it...there is sooooo much wiring and in my mind it was money well worth spent on my part..I've had no issues with mine what so ever. Have a pro hook it up man, seriously.
why have a pro do it when you can buy a harness for $20?
Well the reason i don't want to buy a harness is because my brother is here with me from Indiana and he leaves on sunday morning and I want to hook it up together and i won't be able to get a harness by then.
I bought the harness when I bought the timer...I had my guy hook it up when I was having some stereo work done and a new head unit hooked up to my Eclipse as well...just had him do everything in one shot was all...so if anything goofs up he's the one that has to fix it and it's all on him instead of me having to struggle through it...I'm happy with the work he did, he has 30+ years experience so he knows his shiznit and I trust him...To me, money well worth spent.
well between the 2 links i gave you on the TT install and looking up on VFAQ for the ECU wiring diagram you should be able to figure out where to splice the wires
RE: How to Install Greddy Turbo Timer? 2G
where does the TT harness plug into in the car? i saw em and always wondered....
