how & where to install nos on 2nd gen
i got a 98 eclipse w/ hahn racecraft stage II turbo, with 20g turbo @ 8 psi with center intercooler. i want to know where & how i should install my nitxpress kit???where should i have the nos spray into the motor??? i know a guy that has it spray into the intercooler,,,why would you have it spray the intercooler?????? where should i do it at??? HELP HELP HELP!!!!!!!!!!!!!!11
RE: how & where to install nos on 2nd gen
That one might not be nos, it might be one of those kits that cools the air inside the intercooler.... why would you wanna do that to your engine? PURE pain, get more boost, and then if you cannot boost anymore and still want speed, maybe then you can try it without leaving your engine with internal acne
i got the biggest turbo from hahn racecraft, but i got it set @ 8 psi. i'm thinking about changing the rods & pistions & cranking up the psi!!!! what do u think????????
i think you should not run nitrous to your engine for 2 reasons. 1. your engine is basically puny and will not take it until you have it rebuilt. 2. if you don't know where to insert the jets and don't know what kind of kit you have.... i would not install it. DEFINATLY have somebody else install it.
the reason for an intercooler spray kit is to cool down the boost temps. if you do get any kind of nitrous you will need to tune for it. i'm sure since you have a 20g turbo on a 420a you already have a tune... right? |
You dont need nos if you are running a 20g turbo.. You will never outgrow the limits of your turbo with that car.. Anymore power than what that 20g turbo is pushing out will prolly put a rod through your block.. I think its foolish to even run that turbo on a 420a motor, but hey hahn must have stuff figured out..
are there directions i nthe kit? read em....if u still dont understand i thing u put the spray in ur air intake thats how i see em do it on horse power tv to a stang
Assuming it's a 420a, I wouldn't spray it, period.
and please stop calling it NOS. That is a brand name and tobe honest makes you sound kinda ricey. Its called NO2
N2O is the actual abbreviation, or you could spell it out, NITROUS. :D
wow,,well,,,thanks for nothing!!!!!!!!!!
