i need help
i just ordered a hks ssq blowoff valve and it didnt fit into my hose. someone told me that it didnt have the flange kit. is there any way i can install it without the flange or do i need it.
p.s. i also have on a type rs bov but i dont like the sound of it and want to put on the ssq instead. |
RE: i need help
you are gonna need two things. One is the flange that will have to be used to bolt to the stock intercooler pipe. The other thing you need is the recirc. kit because you dont want to be venting it. Here is a place that has both. If you dontwant to order from there then at least you know what your looking for http://www.dsmparts.com/customer/home.php?cat=9
RE: i need help
you can vent it, but if your looking for more performance than the "sound" you would want to go with that ;)
RE: i need help
thanks guys
RE: i need help
ssq is by far the best out there... and we can't stress enough that you can not vent!!!
RE: i need help
explain why you stress so much why you wouldnt vent?
RE: i need help
because your car will run like crap. It will try and stall out on you when you hit the clutch in and when your comming to a stop
RE: i need help
hey i have turbo or wastegate problem. i took it to my mechanic and the scanner says "over boost" any ideas on how to fix this
RE: i need help
i have bever heard of a code actually saying "overboost" Do you have a boost guage, or MBC. need more info please
