Intake manifold
Hey guys,
I'm thinking about getting a throttle body for my 2000 Eclipse RS. I was wondering where I could get a good intake manifold for my car because the two put together will make it way better than just the throttle body itself. Chris |
RE: Intake manifold
just so ou know. Buying either of those is not going to give you much, if any, of a gain. Your best bet on mods for a NA car is a header, exhaust and intake. Then maybe cams if you really want to get into the engine. But intake mani and TB are kinda worthless
RE: Intake manifold
My friend has a camaro Z28 LS1 and he said it gives him 30 HP when he put his in and his friend has an import and it gave him 35 HP. It reduces the restriction of airflow when you lay the throttle down when you drive, it seems like its good
RE: Intake manifold
there is a HUGE difference between an LS1 and a 4g64. Your talking a 5.7L vs a 2.4L. They will react to mods alot differently. I doubt youll get more than 10hp off this mod
RE: Intake manifold
is that 30 and 35 hp by the manufactures specs? Is that a proven dyno test? Because most things will say this gives you 10hp or 20hp when actually most people see about 3-8.. or none at all..
