| RCJr9186 |
Jun 22, 2007 08:30 AM |
RE: Intercooler installation help
on a 16g (not sure what stage 3 means..... or a stage 3 bov... what is that?) a good injector size would be 550's. you can get 650's or 660's but you will need a FPR if you go that high. as for installing the FMIC.... what do you mean stock? as in, so that you can't see the intercooler? it will take some serious work is all i have to tell you, you would have to mount it horizontally somewhere, not sure where. another option would be to go w/ a liquid to air IC. you are aware that you will also need fuel pump, tuning device, ic piping, couplers, boost gauge, boost controller and a tune to see a noticible difference right? after you get ur car going, you'll need a new clutch not after to long.
