mbc
Old 01-14-2005, 12:27 AM
99clipsgst's Avatar
Default mbc
How hard is it to install a mbc. and how reliable are they. I want to get one to add just like 2-3 psi but a few people said they area cheap way to get hp and can cause major damage if they malfunction.
Old 01-14-2005, 01:10 AM
Default RE: mbc
they are easy to put on.they are very reliable if you get a goodone not a ebay one. just dont turn the boost up over 15psi
Old 01-15-2005, 01:03 AM
99clipsgst's Avatar
Default RE: mbc
what is a good brand and what is the price range? I also would like to know if electronic boost control was better then mbc
Old 01-16-2005, 02:11 AM
Default RE: mbc
The brand names aren't that big, my friend owns his own whole sale business and he dosn't even have a big name brand one, and there isn't that much of a difference from a mbc and a electronic the difference is though that you adjusted electronically instead of you getting out of the car and adjusting it and there might be other stuff but it's really not worth the money.
Old 03-31-2005, 11:21 PM
Default RE: mbc
Some EBC's are known to spike, where as MBCs dont. I'd go with a manual boost controller. I'd recommend the dejon tool mbc.
Old 04-01-2005, 12:32 AM
DSMTalonAWD51's Avatar
Default RE: mbc
a good ebc like the greddy profec b is a very reliable boost controller and wont allow spike. manual boost controllers can spike. however, if you have a reliable boost guage ( and u need one with any boost controller) you can monitor any spike and a manual boost controller will work fine. in my opinion a manual boost controller is reliable enough, the ebc's are just too expensive. i use the turbo xs high performance one, it has 2 adjustment *****, course and fine tuning, and i havnt had any problems with it. it was about $80
Old 04-04-2005, 01:25 PM
Default RE: mbc
Hallman makes good mbc's along with others. The biggest differance between a manual and an electronic are that the electronics aren't as reliable at higher boost levels. Also you should never get a boost controller of any kind without being able to monitor the levels, so a guage should be installed before or at the same time. Hallman also makes a kit so you can actually adjust the levels from inside the car. Some other companies make mbc's that have an electronic two position switch that allows you to switch between two preadjusted levels without any messing around. When I get one this is probably the setup I would go with.
Old 04-16-2005, 07:52 PM
Default RE: mbc
If you don't want to fork out money for those 3 gauge A-pillar sets, you can make one out of ur stock A-pillar cover, piping, and some liquid plastic.
Old 07-18-2005, 09:39 PM
Default RE: mbc
I reccomend using a Apex-i or HKS boost controller. They are the only two brands that i use on my car
Old 07-29-2005, 01:54 AM
Default RE: mbc
apex and HK$ are overpriced/overrated
Quick Reply: mbc
