SEBBA, I found it. 20G...
http://www.vfaq.net/DSM/mods/10faq.html
Or: Max output from various turbos TD05-14B (stock 1st gen) 275-300hp @ 21 psi TD05-16G (small) 345-365hp @ 22 psi TD06-16G (large) 365-385hp @ 22 psi TD06-20G 430-450hp @ 22 psi T25 (stock 2nd gen) 235-250hp @ ?? psi T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi Is this what you wanted to know the other day? |
RE: SEBBA, I found it. 20G...
Just to let you know, where usually not supposed to address a member in the thread name nor should it just be for a member. That is what a pm usually is for. But this is some good info. ;)
Oh, Sorry. I didnt know that. Will not happen again.
You absolute legend!!!
Hope it helps. But then again, you were also looking for turbo lag. If I find that, I will let you know.
nah its cool thats an obvious one.
Hey Sebba, found what you wanted ( I think)
http://dsm.dejonpowerhouse.com/ Click on the website and then under ALL MITSUBISHI click on TURBOCHARGERS |
