turbo cutting out
ive got a 90 turbo eclipse and when im flooring it the turbo runs great til bout 5 and half grand rpm's then the rpm's keep increasin but its almost like the power doesnt get to the wheels. thts the best way i can explain it. i dunno if its the turbo or if its soemthin else. one of my friends thought it might be runnin rich but i thought i would ask people tht know
RE: turbo cutting out
Boost leak test is what I and most would suggest in here for you bro ;)
They drop off lol.... hooray for a ****ty 14b
check bcs..
i'm gonna second Silver... get/make a boost leak tester and check it. also check all or your couplers to make sure they are secure and whole.
Or you might be hitting fuel cut. Check your ecu. Is it throwing codes?
ORIGINAL: andrew rs Or you might be hitting fuel cut. Check your ecu. Is it throwing codes? I would also suspect an MBC and/or a weak wastegate spring. |
