Turbo fitting help!
Hello!
I've been searching everywhere to find out some info on a turbo I have. Apparently it is a TD04HL-13T off of a RVR. My question is this: Does anyone know what size fittings I need for the oil supply and return or drain? Like -4AN or -6AN for example. It's for a custom application. It also didn't come with any so I have nothing to compare it to. Thanks for your help! M |
2005 Mitsubishi Triton (4m40) - VNT Turbo
Hello Everyone,
I'm fitting a Garrett Turbo to my 2005 Mitsubishi Triton as the original turbo has blown up. The turbo that I have bought of someone is a VNT Turbo and Requires a Vacuum line for the actuator. The problem I'm having is that I'm not sure where I can get a vacuum line from? Can it be any vacuum line from the engine or does it have to be from a specific place ? If anyone could help me out that would be great, Thanks. |
