Turbo PSI Question
How much psi am i running on my 97 stock turbo for the GST?
i believe it is the T25 turbo. |
RE: Turbo PSI Question
you dont have a boost controller right? stock is 10-12
yep E is correct
Unless your wastegate is bad.. :D Ive seen much higher with a bad wastegate...
ORIGINAL: TheAdvocate Unless your wastegate is bad.. :D Ive seen much higher with a bad wastegate... |
coolness. if i was to get a boost controller how much PSI could I run safely on my engine?
ORIGINAL: PooT_Nation coolness. if i was to get a boost controller how much PSI could I run safely on my engine? |
ORIGINAL: EMonz57 ORIGINAL: PooT_Nation coolness. if i was to get a boost controller how much PSI could I run safely on my engine? At 16/17 PSI how much horsepower do you think i'd have? |
ORIGINAL: PooT_Nation ORIGINAL: EMonz57 ORIGINAL: PooT_Nation coolness. if i was to get a boost controller how much PSI could I run safely on my engine? At 16/17 PSI how much horsepower do you think i'd have? My friends talon raced me when I was bone stock and he stayed dead even with me and he was AWD, he had intake exhaust 1G BOV upper IC pipe and MBC at 15-17PSI somewhere in there. and the stock 03 EVO dynos 248AWHP |
damn.
i'm gonna have to look into these boost controllers. going to have to get a guage too. |
