Turbo upgrade need opinions
I have a 1996 fwd dsm thats stroked to 2.3 liters, my over all goal is between 350-400 crank hp. what would be the best turbo? I also am getting a quaife lsd, act 2600 clutch, and some proxes ra1s so i can put it to the ground.
RE: Turbo upgrade need opinions
Big 16g turbo. can make around 390HP at 22\24PSI with other supporting mods
Even a 20g would be good for you.. A little more turbo lag but it would give you suffecient hp..
ORIGINAL: TheAdvocate Even a 20g would be good for you.. A little more turbo lag but it would give you suffecient hp.. |
what about a hahn 20g?
hahn makes good turbo's.. Your gonna be paying the price for it though..
ORIGINAL: n2daizo123 what about a hahn 20g? |
I was looking into it because im gonna get a gsx and theres a turbo upgrade for the gsx/gst. the GT30R and it gives you 400 hp. You should look into it.
I have the GREDDY 18g upgrade and a bunch or other **** like injectors and safc and fuel pump ect... and because of stock internals and not wanting to blow my car sky high im running about 300 hp and the turbo is only turned up about 50%..... and it goes realy well.
