91 GSX PCV valve?????
Old Jun 14, 2008 | 06:55 PM
91ricerocket's Avatar
Default 91 GSX PCV valve?????
I have a 91 GSX with a lot of mods. I was wondering what kind of pcv valve I should get? I have read that they are made for specific engines. Well mine is 2.3ltr now and the boost I hope will be high soon. Is a stock one good enough???? I have a cool looking thing with a different pcv valve I made. Any help would be cool.
Old Jun 14, 2008 | 10:10 PM
BrunoBoy650's Avatar
Default RE: 91 GSX PCV valve?????
leave it OEM, and btw, whats with your username? looking at it makes me think you should just hand over the gsx........
Old Jun 15, 2008 | 09:12 AM
I have seen people without them and just a hose to a catch can. Is this something you can just tune through?? I have dsm link I just want to get running perfect. I figure a pcv valve could smooth out my idle. Car is still being built. Your input is appreciated, also I hate newbie up there too. HOW DO I GET RID OUT IT???? I think I have to just keep posting...
Old Jun 15, 2008 | 11:24 AM
dsm1990gsx's Avatar
It'll change w/ more posts you have.
Old Jun 15, 2008 | 11:28 AM
dsm1990gsx's Avatar
Just use the stock pcv valve and do u still have the emission stuff on your car?
Old Jun 15, 2008 | 02:59 PM
tidus10's Avatar
why are all my posts getting deleted?
Old Jun 15, 2008 | 04:19 PM
All emisions stuff is gone. EGR capped no canister and stock regulator gone.If you need to know anything else let me know. I dont know if I need to recirculate it back to the intake or if I can run to catch can and tune it out. I think I need a pcv valve either way. YOu tell me???
Old Jun 15, 2008 | 04:22 PM
silvercoupe97's Avatar
The PCV valve isn't for emissions. It's a one way valve. It opens when there is flowing positive pressure inside the intake manifold to pull the valve open. This sucks pressure out of the valve cover (or was that the other way, lol). Leave the valve OEM, there's absolutely no need to change it, even with a modded motor.
Old Jun 15, 2008 | 04:23 PM
It's also there to keep the sudden wall of pressure out of the head when you let off of the gas pedal.
Maybe you should change yours since you mentioned blow-by in another post.
Old Jun 15, 2008 | 04:28 PM
IMO, keep the lines as they are. There's a good reason it's there. It helps purge the oil vapors from the cover. A catch can won't do that, unless you put an in-line catch can in place.
