Clutch squeak question
Yesterday we changed my brake pads to get rid of my brake squeak since they were worn so much. My ride was so nice with no noise after that.
Hatchetman9449 noticed I was low on clutch fluid so we went and pick up some dot 3 and put it in. then drove back to his house and i left the car there for about 9 hours. When we get back I leave and evertime I let out the clutch now there is a squeak type noise. Anyone know what this is or how I could fix it. Thanks. |
RE: Clutch squeak question
is it definately outside the car or inside??? if its inside probably the spring thats on ur clutch pedal
Not positive. Havent looked at it closely since it was 1a.m. when I noticed it.
But now that you say that when I first heard it, it did sound like a spring to me. |
probably just the spring, nothing to worry about. Or you just need to grease up the linkages a bit
Alright, thanks I'll take a look at it tomorrow.
Yeah it is the spring i had the same thing in my 05 lancer you can either ignore it or grease it up and it should go away
Where is this spring located exactly?
