gst heal?
so i belive my gst had an oil leak i was putting aprox a quart of oil in it every week or so and now when i check it it hasnt dropped at all. i dont know if maybe i was burninga lil xtra oil when having some fun (wot) but everything seems good know. has anything like this happened with any of your cars? or any opinions why i might not be needng to put oil in as much as before thanks.
RE: gst heal?
has with me...then i did get a leak at the oil pan gasket...10 $ llater i fixed it
RE: gst heal?
but get it checked out b4 anything
RE: gst heal?
I have similar problems with my gst. The oil level will be fine for about a month or so and then all of a sudden will drop like a quart. I still cant figure out why.
RE: gst heal?
my gs-t always burned oil alittle bit, then I started using castrol syntec with alittle bit of lucas oil stabilizer. have you changed oil brands?
RE: gst heal?
no i havent changed oils would that make any difference? i am using castrol as well but i need to have my oil changed and hopefully they might be able to tell me where this "leak" is so i hope that helps. i could really use some tips on how to clean the engine bay like what to use. i dont want to get everything wet just with some kind of brush get all the black gunk oil grime off it so it looks cleaner any suggestions
RE: gst heal?
ORIGINAL: burnmyeyes my gs-t always burned oil alittle bit, then I started using castrol syntec with alittle bit of lucas oil stabilizer. have you changed oil brands? |
