how hard is it to convert to awd?
Old Sep 3, 2006 | 04:24 PM
hatchetman9449's Avatar
Default how hard is it to convert to awd?
i found an engine for sale that is said to have 500hp+ and did the 1/4 mile in high 11's.... but the engine is for awd and i have fwd. how had is it to convert because if i could get my car doing high 11's i would have to poop my pants.
Old Sep 3, 2006 | 04:55 PM
Default RE: how hard is it to convert to awd?
not gonna happen
the motor is no diff from the FWD motor the diff is the tranny so use the FWD tranny and your good to go
Old Sep 3, 2006 | 04:57 PM
so if i buy it, it will just fit like a charm? and are you saying the high 11's isnt going to happen?
lol. its just what im told, and he also said thats at only 15psi... that makes it more unbelieveable
Old Sep 3, 2006 | 05:00 PM
my car can run high 11s if I had cams and at 22ish PSI.
the 11s isnt impossible but the AWD conversion was what I was saying wont happen. neither would high 11s on a FWD car unless you find some nice drag radials since traction wont be your friend
Old Sep 3, 2006 | 05:09 PM
ok thanks, but just for a final make sure it will fit, this engine will slide right into my car like any 4g63t fwd would?
Old Sep 3, 2006 | 08:40 PM
ORIGINAL: hatchetman9449
there is no difference between the 4G63 motor for FWD or AWD the motor is the same the drivetrain is the difference
Old Sep 4, 2006 | 01:39 AM
emonz, my step dad is a deasel mechanic and he is telling me that an awd engine usualy wont fit on a fwd...
Old Sep 4, 2006 | 01:41 AM
yes it will it is no different from FWD the motor is the same the difference is the tranny.. how do you think guys with 2G eclipses and talons swap in the 6 bolt 1G motor
Old Sep 4, 2006 | 01:43 AM
Your motor is differnct from the 4G63 but as far as I know they can be swapped in those it is the 420a engine in the RS GS 2G eclipse\talons that cant be swapped with the turbo motor
Outlaander
Nov 14, 2018 09:50 AM
tw0000
Dec 12, 2011 05:11 PM
kmauger07
Aug 23, 2007 11:37 AM
night_turbo99
Aug 7, 2006 05:10 AM
Tucson302
Sep 6, 2005 02:24 AM
