RE: i suck
ORIGINAL: dsm1990gsx ORIGINAL: estraw ORIGINAL: dsm1990gsx Your 60 ft times suck and in run 1 there is no way its 1.0. How did you launch? |
RE: i suck
ORIGINAL: EMonz57 2.5 60fts? What the hell were you doing? You def should be in the 1.7 range at least. That alone will run you closer into the 14s |
RE: i suck
ORIGINAL: BrunoBoy650 ORIGINAL: dsm1990gsx ORIGINAL: estraw ORIGINAL: dsm1990gsx Your 60 ft times suck and in run 1 there is no way its 1.0. How did you launch? |
RE: i suck
Yea you need to slip that clutch alittle more and get rid of the damn ebrake. There is no need for that. Even on my RWD i was hitting 2.1. You should be below 2.0 at least.
And what is with the very low traps...you should be hitting around 95mph. Is something wrong with your car? Are you having problems shifting too? |
RE: i suck
After you launched did it bog down?
RE: i suck
ORIGINAL: TheEngineer Yea you need to slip that clutch alittle more and get rid of the damn ebrake. There is no need for that. Even on my RWD i was hitting 2.1. You should be below 2.0 at least. And what is with the very low traps...you should be hitting around 95mph. Is something wrong with your car? Are you having problems shifting too? |
RE: i suck
wow. my a/t gsx runs 1/4 mile in 17.01 sec. just like the hondas...
RE: i suck
ORIGINAL: ProjectDrknss wow. my a/t gsx runs 1/4 mile in 17.01 sec. just like the hondas... |
RE: i suck
No, it's not a 1g. It's the 2g you see in my picture. |
RE: i suck
So the whole time you are sitting at the light you are roasting the clutch?
