Valve clearance
Hello all,
Could some knowledgeable gurus please enlighten me about the valve clearances on the 4D68 ext R2SB engine? I have two possibilities but not sure which is right: 0.25mm I 0.35mm E or 0.15 for both Grateful thanks Martin |
RE: Valve clearance
So I asked around, (not ever had to ask a question about a 4D68 before), but the guy I talked to said that they should both (inlet & Exhaust) shouldbe set at .25mm hot
RE: Valve clearance
Ahh, thanks! I think it's a good compromise. Thank you for going to the trouble. It's much appreciated.
Martin |
RE: Valve clearance
no problem
