02 Eclipse Spyder GT wont start - too much fuel, please help!
I have a 2002 Eclipse Spyder 6cyl that wont start, and Im having absolutely no luck getting it going again. The situation right now is that if I disconnect the fuel pump, crank the car until it kicks over, and quickly reconnect the fuel pump it will start and idle. However as soon as I give it gas it just dies. If I try to crank it again it wont start, and when pulling a plug its obvious that the engine is getting way too much fuel. The only code that the car has thrown was for the EGR system. The below list is what I have tested so far, all without any positive results :(
-Replaced MAF -Replaced FPR -Replaced fast idle stepper motor -Verified EGR valve is functional -Tested EGR solenoid - stuck open so I plugged it for now and ordered a replacement -Verified spark (at least on the front 3 cylinders) -Verified TPS is working properly -Ran half a bottle of Seafoam through the engine -Checked for other vacuum leaks I think that its unlikely all 6 injectors died at the same time so at this point Im really at a loss as to what to do next. |
Bump...anyone?
