Throttle body issue
Throttle body issue
You
Hi, I have a 2008 outlander and sometimes it won’t start, we worked out the butterfly valve was staying closed when tried to start it, so have to pop the large hose off and push butterflie valve with finger to get it to respond, then it’s fine for a few days or a week then out of the blue it won’t start, entill I pull the hose off and push valve manually, I replaced egr valve and throttle body with brand new one last week thinking that would fix it but today it did it again, literally I’m lost what is causing this issue, please can you shed any light on this
