1997 Mitsubishi Gallant ES/304k miles - Fuel delivery sporatic
The car cranks and cranks but won't start. So I pulled the fuel line off the fuel rail and put newpaper under it to see if it would get wet with fuel. First 2 - 4 second crank, nothing. No fuel on paper. Then I crank it again and there IS fuel on the paper. Maybe like there is a pressure leak. Or a short in the pump itself. I can't check the fuel pressure with the fuel line connected to the fuel rail because this car didn't come with a shrader valve. So I'm thinking there either is a leak in one of the tubes going to the fuel pump or the fuel pump has got some kind of short in it. Anyone got any ideas?
Oh yeah, don't know if this makes any difference, but I did not have any problems until I let the car idle to charge up the battery and forgot about it and it ran the tank out of gas. |
Originally Posted by Toddo
(Post 297436)
as for your problem. COULD be a connection thing. or, could be air in the lines. fill the tank, switch key to ON (if fuel pump runs while on?) until fuel is at the lines (above the cyls), plug the hose back on and you're good to go. if pump wont run at ON, you need to bleed the fuel lines.. |
Originally Posted by Akzle
(Post 297450)
or, could be air in the lines. fill the tank, switch key to ON (if fuel pump runs while on?) until fuel is at the lines (above the cyls), plug the hose back on and you're good to go. if pump wont run at ON, you need to bleed the fuel lines.. If air in the line is causing the problem, then all I should need to do is make sure there is plenty of gas in the tank, remove the fuel line from the fuel rail and then get somone to crank it over and over while I hold a cup under the end of the fuel line to catch the fuel. That should push fuel through the line and any air in the line right up the fuel line and out the end of the fuel line I would hope. |
| All times are GMT -5. The time now is 03:39 AM. |
