2000 montero random no start???
Old 12-17-2015, 09:00 PM
Do you know where the ASD relay is located?
Old 12-18-2015, 05:46 AM
No I don't but I think I located the problem, there is power to the fuel pump relay and the relay is sending power to the pump but im getting no fuel so I think the fuel pump is bad
Old 12-24-2015, 12:26 PM
Ok ive replaced the fuel pump im still getting no power to the fuel pump whatsoever maybe it could be this ASD relay??? But does anyone know wherevthis ASD relay is??? Im getting powe through the fuel pump relay but notjing to the pump, also does this vehicle have an inertia switch
Old 12-24-2015, 06:49 PM
Default Random no Start
I spoke with a certified Mitsubishi mechanic and he is certain that it is a faulty crank sensor. He said they are known for being troublesome.,especially aftermarket. Everything starts or stops with the crank sensor. I'll the sensor doesn't sense crank rotation it will not send power to the fuel pump, or spark to the plugs. I found a Mitsubishi factory sensor for about 60.00 and my local mechanic estimated about 350.00 labor.
If anyone can confirm or has a different ideas I'd love to hear it.
Old 12-25-2015, 06:24 AM
Ok thank you I thought about the crank sensor, but I am getting spark just no power to the fuel pump, so could this still be a crank sensor???
Old 04-03-2016, 03:47 PM
Ive changed the pcm, fuel pump, fuel pump relay, camshaft sensor, and still no power to the fuel pump, I have no codes, I do have spark, absolutely no fuel is pumping, so I need clarification, could the crank sensor still be bad under these conditions???, there is a relay under the hood with a engine symbol on it, could this be the auto shut down relay im so stumped on this piecd of crap, Im ready to have a bond fire!
Old 06-03-2016, 10:44 AM
Default Alarm immobilization?
Did you ever find cause?
I have a 2003 Montero Limited did similar thing, but only without starting. It never died in motion.
I'm not sure but think it was an alarm quirk. Disconnect battery for 24 hours (both leads). Connect again and then lock the doors with switch or keychain, and then unlock with the door key and keychain.
I'm not sure but that's what I think worked for my issue.
Old 11-30-2018, 10:04 PM
OK update I'm still working on this POS, installing a new wiring harness, can anyone give me information about the fuel pump control module, someone told me that if these are bad they will cause the truck to randomly shut down, is there a way to bypass this unit?, what is its function?, takes for the info
Old 11-30-2018, 10:21 PM
Oh and also I discovered when my timing belt broke 2 years ago, it ripped the cam sensor wire and the big 100amp buss fuse blew I'm think something got shorted out any one want to have a bond fire? I'm at that point with this car!
Old 12-20-2018, 08:57 PM
Does anyone know what this connector plus into?, its on the passenger side by the fuel pump and MFI relays in a 2000 Mitsubishi Montero Sport
Quick Reply: 2000 montero random no start???
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
