Car stalling
Old Nov 17, 2007 | 04:00 PM
1cor118's Avatar
Default Car stalling
While driving, my 93 mitsubishi galant occasionally stalls. I can restart it but when I turn it over, and it doesn't start, I have to turn the ignition off and back on before it will restart.If I try and start it without turning the key back off, it will just turn over. When it does start, occasionally, it will diesel until I turn the key back to the off position, wait five or ten seconds, and then it starts fine.
Any suggestions will be appreciated.
Old Nov 18, 2007 | 12:16 AM
JStrateger's Avatar
Default RE: Car stalling
Sounds like a spark problem to me, Check the coil pack. I'd go ahead and do a tune up, get new spark plugs, new wires, change the oil, oil filter, run some in the gasoline seafoam/injector cleaner.
Old Nov 18, 2007 | 02:33 PM
1cor118's Avatar
I'm thinking along the same line. I'm going for the coil first. Oil change is scheduled within the week. Replaced the fuel pump last week. It runs good just being a pain this week. I'll let you know how it turns out. ThanksJStrageger.
Old Dec 4, 2007 | 11:03 PM
1cor118's Avatar
Hey, JStrateger. Good call. I replaced the distributor with the built in coil pack, and ignition module and then replaced the rotor and cap. Runs like a top. Thanks
Old Dec 4, 2007 | 11:05 PM
I could have told you.
It was the ignition control module.
jenkins
Feb 28, 2008 09:02 PM
shylae21
Nov 8, 2007 04:59 PM
PooT_Nation
Mar 6, 2006 05:39 PM
cocosun
Aug 9, 2005 01:52 AM
get435
May 22, 2005 03:12 PM
