Engine Code P0171
What is with you and injectors? lol... Evo3 big 16G, but theyre all relatively the same arent they. That would all go fine with an auto. You just really wanna use that fuel rail dont you?
if i go with the Evo 3 16g would i have to get bigger injectors or would the stock ones still work. i dont want to have my car running on lean conditions. I will probly use that fuel rail because i am going to be putting in some gauges and one of them will be a fuel pressure guage so it already has a spot for me to put it on there.
The E316G is your best bet in that lineup.
This FAQ has a perfect explaination of this turbo and a fuel setup.
https://mitsubishiforum.com/m_125438/tm.htm
Auto tranny...it all depends on it's current shape. That also goes for the motor. Do not mod your motor is your motor hasn't had a current tune up. In other words, if your car is missing here and there, if your car has a rough idle, if your car...blah, blah, blah....don't mod it until your car is in better condition. This is also a reason to do a compression check, a boost leak (it's always a good time to do this). Just use your common sense, don't rag out an already ragged out motor.
ORIGINAL: 98gstspy
You've got a turbo car, IMO, don't bling it. It's made for power and can be made to put out more power. If you want to bling an Eclipse, buy a cheap GS/RS and bling it....no offense to our GS/RS members
Ok so I bought a short ram intake pipe for my outlander and I had to modify it to fit my map sensor on it . So I installed it after that and it popped the Lean code . I've done some research and it pops eighther from the vacuum hose after the map sensor ( not good fitting , loose rubber grommet hose is in .) Or from the warm air from engine because I read that the cold air intake pipes that are put on away from engine bay suck in actual cold air and don't affect the map sensor . So my question is should I extend the pipe to front of grill or add shroud around it with a little scoop on hood or do I just need to take it off ?
crash77
Dec 19, 2013 10:57 AM
