Fuel injector problems
I have a 1990 Mitsubishi Mighty Max with 3.0 engine and the fuel injectors will not work. I have checked everything i could think of but not go. It fires fine and will hit if gas is put in cylinders and fuel pump is new.I have also put new dist. in if you have any ideas let me know.
RE: Fuel injector problems
did u get new injectors?
Check to see if you getting an injector pulse? If not look into the mpi relay or pcm.
